2000 F45 to F55 Shock Replacement
St. Jude Donor '14-'15, '17, '19
I have been told I can put F55-magnetic ride control shocks- in my 2000 F45 equipped car because the F45 wiring harnesses are compatible with the F55 shocks. The only difference I am told is I will have two selections instead of three. Is this true? Thanks, Mike
It has been done but at a substantial cost and with a bit of work to do the conversion. I had a forum member send me the info on how he did his conversion but it cost a pretty penny and was a significant amount of work.
http://www.gmpartsdirect.com/results...umber=12499507 What about this????
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
OK, from one that made the swap to the F55 (on my '99).
I purchased the F55 system from a Forum vendor.
It took all of 2 hours to change out.
It was NOT difficult.
It did make a SUBSTANTIAL difference in ride 'feel'.
Years ago I posted on this Forum the process.
Do a search - I am too lazy.
This thread started to be question and your quickly turning it into a sarcastic malicious number of posts. Maybe you should try smoking some of your own stuff and chill out. Your initial answer turned out to be wrong and I guess it must be bothering you.
