Drag radial size ideas
Old 08-12-2013, 01:51 AM
blacknyellow
blacknyellow's Avatar
Default Drag radial size ideas
I got 18x8.5 in front and 19x10 in the rear.
I DON'T want to use my current rear wheels and was thinking of maybe a 17 or 18 might work. What size wheel and radial do you recommend?
Old 08-12-2013, 07:27 AM
DevilDog II
DevilDog II's Avatar
Oldtimer
I'd probably go with an 18" drag radial on the rear if it's primarily for street use. I ran 18" BF Goodrich's on mine years ago and my car hooked up pretty well on the street. Tire technology has come a lot further since then and you have several more choices now. If you're just looking for track use, I'd be tempted to go with a 17", which would give you a little more sidewall. I'm sure someone with DR's will chime in.
Old 08-12-2013, 08:33 AM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Default ttt
Look at the 17 on the rears. More tire in a 17 but get the tallest one you can find.. Robert
Old 08-12-2013, 03:53 PM
blacknyellow
Ttt
Old 08-12-2013, 04:26 PM
Maxx_Z06
Maxx_Z06's Avatar
C5 COTM Coordinator
Just wondering why you don't want to run 19's in a drag radial?
For my new setup i'm thinking 325/30/19 Hoosier R6 or A6....
Old 08-12-2013, 05:35 PM
blacknyellow
Possibly to heavy maybe?
Old 08-12-2013, 06:24 PM
DevilDog II
Oldtimer
Just found them on Tire Rack. I'm sure the price will scare some folks away.
Old 08-12-2013, 07:10 PM
PhysicsDude55
PhysicsDude55's Avatar
A 17X9.5" wheel will fit most drag radials well. That's the stock size for front Z06 wheels, so its a pretty easy and cheap size to find.
I'm personally about to put on some Mickey Thompson 295/45/17's. They're a ~27" tire, so a little bit more sidewall that the stock ~26" tires, but it doesn't require any tubing or trimming or anything like most 28" tires do.
I think a 295/45/17 is pretty much the biggest drag tire you can fit on a C5 without doing any modifications to the car.
Old 08-13-2013, 01:56 AM
blacknyellow
I couldn't find a DR to fit that rim.
Maybe I should get 18x8.5?
Old 08-13-2013, 07:16 AM
Maxx_Z06
Maxx_Z06's Avatar
C5 COTM Coordinator
Yeah they're not the cheapest tire out there. My buddy is running them in his c6 z06, performance wise they do tame the monster.
Old 08-13-2013, 09:12 PM
gradykd
gradykd's Avatar
Default hey
You couldn't find DR to fit 17" rim? There's plenty. I got my Nitto 555r's 135.00 each.
www.onlinetires.com
Old 08-13-2013, 10:03 PM
PhysicsDude55
I couldn't easily find a true drag radial for a 17"X9.5" rim, but I think one probably does exist.
I'm going to run these:
http://www.mickeythompsontires.com/s...StreetRadialII
Those or Nittos are your best best, and you can run them on the street too.
Old 08-13-2013, 11:38 PM
Black 02
Black 02's Avatar
275/40/17 will work fine on the 17x9.5.
To Drag radial size ideas
Quick Reply: Drag radial size ideas
