u haul auto transport
Does anyone know if a original height c5 will go on a U Haul auto transport trailer without using boards on the ramps. The front should clear the stops. I'm at 7" in the front. Tks.
I have used U-haul transports for my C5. You will have to use some kind of extention on the ramps. The car is just too low to go on the trailer without scraping. I used some 6 foot ramps with the trailer ramps to smooth out the transition. You can also back up to a bank to make a straighter transition onto the trailer. Be careful of the front spoiler on the front of the trailer. I removed mine so as not to rip it off. As I remember, I had to enter and exit the car thru the hatch because of the fenders on the trailer will hit the doors if you try to open them. Hope this all helps. Other than these things I liked the U- haul and will use them again.
The Outlaw
The Outlaw
Most Uhaul trailers now have the fold down fender on the driver's side. Fold it down before you start. Open the door carefully in case it doesn't go low enough to clear your door. If you can put the back of the trailer up to an upslope as in a sloping driveway, it will usually clear. I've never had to remove anything on the front of the car.
U-Haul has a page with tips on loading low cars into the auto transport. If you use a few planks of wood per their recommendation, you won't have any issues. Just need something to extend the ramps, and some wood to prop up the front so that the bumper doesn't hit the front of the trailer.
http://www.uhaul.com/Articles/Tips/1...ound-clearance
Just got done loading/unloading mine a few days ago. My trailer was silver in color, not red like the one in the above picture, but what I did was to lower the jack while the trailer was hooked to the hitch. This raises the front of the trailer several inches. It pulls the tow vehicle up by the ball, but I'm not talking an extreme amount. Just enough so the nose clears the ramps.
Doesn't take much.
Doesn't take much.
