Key FOB issue
Old 07-22-2014, 03:38 PM
cmark84
cmark84's Avatar
Default Key FOB issue
The other day I managed to drop my key fob on the pavement. After picking it up, I was unable to lock the door. I tried to reprogram the key and had no luck. So I decided to replace the battery. I was then able to get it to learn the fob again, however, the next day, it seemed to have forgotten it. My car can't seem to retain this in memory.
Any ideas what else to try?
Side note: I only have one key/fob so when it prompts to learn the second key, I just clear out the DIC and remove the key from ignition. Test the key to see if it works and then lock the car.
Old 07-22-2014, 04:09 PM
65GGvert
65GGvert's Avatar
Received 3,220 Likes on 2,302 Posts
What year is your car?
Old 07-22-2014, 04:20 PM
cmark84
cmark84's Avatar
It's a 2000. Never had an issue with the FOB until I dropped it.
Old 07-22-2014, 04:31 PM
grunz95
Support Corvetteforum!
grunz95's Avatar
PM sent
Old 07-22-2014, 05:10 PM
65GGvert
65GGvert's Avatar
It's a pretty common symptom for a 2000.
Take a look at this:
http://www.google.com/url?sa=t&rct=j...71198958,d.aWw
Old 10-14-2014, 04:51 PM
cmark84
cmark84's Avatar
Thanks, i'll give this a shot.
To Key FOB issue
Quick Reply: Key FOB issue
