Newb Valve Train Questions. (Non-Vette)
I'm working on an engine of an unknown history. It may have been used as a race engine based on the monster valve springs. And not all parts are there and I'm trying to piece it back together to make it streetable. But first time doing this and lots of unknowns.
1. Are these lifters Hydraulic Roller or Mechanical Roller? They have no part number or any brand name markings on them.
2. The cylinder head had springs, but no studs or rockers. I bought some Scorpion Roller Rockers and ARP studs. However I'm having a mental block on how these go together. It seems like the the stud 'seat' should fit inside of the slot in the bottom of the rocker. However the stud seat is too big so the rocker is going physically sit on the seat once its tightened and then it won't move. I thought I must have gotten the wrong kind of studs, but I don't ever see studs being sold in different seat sizes. There are different lengths and different sizes like 3/8, or 7/16, but all seem to have the same seat size. What am I missing? How do I keep the rocker off the seat, or tighten down the rocker and still allow it to 'rock'.
You have the stud upside down. The hex end goes into the head. There is a nut that holds the rocker in place as it sits against the spring on one end and the pushrod on the other. The rocker just pivots on the shaft of the stud.
I would guess mechanical roller as Ive never seen a set screw on a hydraulic setup, it would also have bleed holes. Is the plunger depressable and adjusted by them? Id assume so; if not they aren't hydraulic.
Also, yes that rocker stud is upside down and missing the stanchion pivot and washer. Be sure to use the correct locking nuts on the top side.
St. Jude Donor '15
The stud is not upside down. If you notice the flat spot is under the hex and curved above it as seen in the picture. Remember this is a non ls1 motor. Old style sbc/lt1 motor. Fine thread size goes through the rocker trunion. Course thread size screws into head. Unless it is a ls1 motor and converting to adjustable setup.
St. Jude Donor '15
Thanks for the replies.
The lifter set screw is for the where the bar attaches on the other side to connect to the two lifters together as previously mentioned so they don't spin in the bore.
Stud is not upside down. On this cylinder head the base the stud screws into is flat, so obviously the flat side of the hex fits the flat base on the head. I'd agree with the first response that the spring should keep the rocker off the hex seat.
Still looking for a sure fire method to determine if the lifters are hydrualic or not. Everyone seems to be leaning toward them being solid rollers, but how do I know for sure, as this will effect the cam selection.
