column lock bypass c5
Received 19,300 Likes
'20-'21-'22-'23-'24
But if you want a CLB, try a place like Mid-America Motorworks.
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Google " Compliance Parts " Read about the LMC5. Far better solution to the Column Lock Bypass (CLB).
You can order from the web site or Ebay or call them.
Less expensive than a CLB, easier to install and a better solution because it abandons all the factory and/or recall wiring and mods.....
I consider the LMC5 to be the best Column Lock problem permanent fix out there. It also does not require you to “undo” any previous CL attempts to resolve this issue. Their eBay ads have a good video that shows the install at the BCM. It does not cover everything in the written instructions. So, read the instructions and also here is some extra info. In some cases, the BCM timing is off just enough to cause some issues. They make several versions and they can swap out/provide one of these if you have any issues. Their customer support is as good as it gets.
Not uncommon for people to "put the column in a pre-lock condition" and not know it and then start with the install. In other words, they started with the column lock “energized’ even if it was not actually locked yet. If not actually locked yet, it will be as soon as you turn the steering wheel after the LMC5 install. It will then remain in the locked condition until you cause the motor to unlock. It will then remain in the unlocked condition since the motor is then unpowered with the circuits disconnected.
Here is one way to prevent that if your column locks and unlocks normally:
If the CL is functioning normally you don't not need the Unlocker, merely turn the ignition ON, pull fuse #23, turn ignition OFF, turn the steering wheel (left and right) and verify it is unlocked. Next, disconnect the negative battery terminal, re-insert fuse #23 and continue with the install.
Compliance Parts website: http://complianceparts.com/index.html
