Best rotor and pad combo under $250
I am looking for the best set of drilled and slotted rotors and pad for under $250. Let me start off by saying this Vette is not tracked or raced at all. Just out on weekends etc. It is a 99 and still has the original rotors and one or more is warped so time to change them all.
there was a vendor here https://www.corvetteforum.com/forums...9-shipped.html
205 shipped...they are on ebay now
For that amount of money you want to spend, you are not going to get quality drilled/slotted rotors and pads. Maybe $250 per axle would be reasonable.
Unless you want the "bling" appearance from the rotors and considering you don't push the car, look at OEM replacements. Raybestos, Centric, and NAPA are all good quality rotors. Stock GM pads will work fine too for your application. There are a variety of stock-style pads available too. Look over at Rockauto for some decent deals.
Brakemotive gets great reviews from everyone on the forum, myself included. Drilled and slotted rotors, zinc coated, includes pads. Fantastic product at excellent prices.
As stated by Chicago1, they are available on e-bay, with free, fast shipping. Can't go wrong. (They are actually on sale right now for $170 full set including ceramic pads).
Forum poll:
https://www.corvetteforum.com/forums...ed-rotors.html
E-Bay link:
http://www.ebay.com/itm/FRONT-REAR-4-PERFORMANCE-DRILLED-SLOTTED-BRAKE-ROTORS-AND-8-CERAMIC-PADS-M590-C5-/390411249426?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACorvette&hash=item5ae652e712&vxp=mtr
Forum poll:
E-Bay link:
Forum poll:
E-Bay link:
Front Rear 4 Performance Drilled Slotted Brake Rotors and 8 Ceramic Pads M590 C5 | eBay
Forum poll:
E-Bay link:
I have the brakemotive setup and have no complaints.
Received 3,812 Likes
St. Jude Donor '03-'04
its always best to buy the cheapest rotors and pads that you can find...
Rotors
The ole' $ .02 worth reply. I currently run cryro/cad drill/slotted rotors with powerstop semi-metallic pads on my 99' FRC, and upon the time to replace them in the future I will go with 'slotted' rotors 'only' (my choice). Please do a little research on rotors and pads and you will see a lot of varied opinions. You will only benefit yourself, your car, your passengers, if you spend just a tad more to get a good grade set of rotors. If you are wanting the bling factor, that's Ok, but when you see what rotors are put on top end performance sports cars ( foreign or domestic) they are equipped with 'slotted' mostly. In the end you will make the choice and money can certainly be the determining factor, so whatever you choose make sure you properly season the rotors and bedding of pads to obtain the best results of whatever you choose. By the way look at what C7's are running, Good Luck and have fun !!
Received 19,307 Likes
'20-'21-'22-'23-'24
Brakemotive does get good reviews from owners here on the forum. Certainly worth looking into.
Centric premium blanks and stoptech street performance pads is the best bang for the buck by far. Forum vendor KNS Brakes has the combo for $276 shipped:
http://www.knsbrakes.com/c/car-serie...nce+Brake+Pads
In truth, I've been running some generic drilled rotors for 40K and haven't had any issues. When it's time to replace I'll probably go with the setup recommended by troyguitar.
BTW, next to the BMW brake design and compounds.. the C5 Corvette brake design was the absolute best factory brake design offered in the country at the time.. we spent a lot of time testing BMW compounds...they don't use Ceramics and they are the dirtiest compound, but they do the absolute best job in stopping under a panic.. the dirtiest pads compounds are the best for stopping ability... hard ceramic pads are the absolute worse, as I have said hundreds of times.. I often think about those wanting less dust, and in the end when they scrape someone up off the highway because they chose ceramic pads and could not make a successful panic stop some one would say " yeah but he had no brake dust on his wheels.
98VetteRagTop (08-05-2017)
FWIW I use the stoptech pads for street and autox, no fade in threshold braking from the rev limited in 2nd gear on sticky-ish Bridgestone RE-11 tires. They're not ceramic or low dust, they simply work well and are cheap. I use spray wax on my wheels so the dust doesn't stick that much, you can blow it right off with compressed air.
Supporting Vendor
St. Jude Donor '11,'13
Get a set of Carbotech 1521 pads and centric rotors. This is a quality set up that performs and will be quiet and low dust.
F: pads $140 R: pads $120
F: rotor $50 R: rotor $41
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
My one attempt at sarcasm... considering the hundreds of posts I've made on quality brakes and rotors.....that fell on deaf ears... I find it funny that quality brakes and rotors are the things that stop the car.. asking for cheap brakes and rotrs is like asking for a cheap brain surgeon... people can go through life and never need a high quality rotor, brake pad compound or quality tire. So anything they buy they endorse... Only scientific testing at all demand levels can give you real quality results... the difference between quality pads and rotors could be 20 feet in stopping distance... and when you ask your cheap rotors and pads to get you to stop from going head on into a jack knifed gasoline hauler, where you only had 100 feet to stop and your cheap pads and rotors were only capable to stop you in 120 ft.. which puts you 20 feet into the Gasoline hauler. Brake pads an rotors and tires are something you should not chap out on... most people on this forum never had to make a panic stop on the highway doing 70 + , and ABS requires incremented stopping pulses.. ABS alone does not make for a shorter stopping distance. AS many people think...if Abs was the sole discriminator, then there would not be the need for so many compounds, so many rotor designs, so many test to check for fade under load.. My sarcasm in this thread was in an attempt to point out that its not really a good idea to buy inexpensive pads and rotors because so many people say so People who never had to actually use them to save their life or never spent a minute on a test track..
Despite the negative comments, at the time I needed rotors due to some more expensive rotors cracking, and I was low on funds at the time, so I took a shot based on the good reviews of Brakemotive. I paid $180 for 4 brand new d/s rotors with pads, shipped. I have been extremely surprised. These have worked great and many miles later are still working great. No cracking, rusting etc. I am thinking though of replacing the pads with something that has better initial bite and getting more wheel cleaner (lol). Maybe then the rotors might not last so long, but right now they are holding up great and the car does stop extremely, surprisingly well. I'd still recommend the Brakemotive set.
When it comes time for new rotors I will buy from them again !
