2004 Rear Road/Tire Noise?
1 Post
Hi...............I looked at a 2004 convertible, 6-speed with 50k miles. Seemed to have a lot of road/tire noise from the passenger rear, even with windows open. Has Goodyear Eagle F1's Tires are not new and need to be replaced. I am a new to Vettes. Is this typical of C5's?
Any ideas?
Thanks, Scott
Any ideas?
Thanks, Scott
That's exactly what we own... some of it's probably those tires... we put non-run flat Nittos on and it is much quieter and I haven't even started sound deadning. We drove coupes and the Vert was quieter to me....
This is a GREAT link
https://www.corvetteforum.com/forums...heelwells.html
Any ideas?
Thanks, Scott
Any ideas?
Thanks, Scott
Received 19,309 Likes
'20-'21-'22-'23-'24
Worn out or just old, hard tires will give you a lot of noise. Replace the tires with a new set, especially non-runflats, and the noise should be vastly improved.
St. Jude Donor '15-'16-'17-‘18-'19-'20-'21-'22
Any ideas?
Thanks, Scott
Any ideas?
Thanks, Scott
They're quiet, smooth riding, grip well wet or dry, but are a little pricey.
http://www.tirerack.com/tires/TireSe...turer=Michelin
1 Post
Is there a local Corvette club in your area -- maybe get a test ride in a member's C5?
If you fill in your location/profile -- there could be a forum member close by.
When we started looking we went to a big dealership in a large town and looked up adds for cars we might be interested in on the way to and from the dealership.... we were able to compare the coupe, convertible and FRC stick and auto.... go drive some, before you commit.
It's normal to hear a lot of noise from the rear of the car. Old GY tires seem to transmit the noise right inside....they also seem to get noiser when more worn.
It's a fiberglass tub in back with a couple small pieces of foam under the carpet. It amplifies road noise. A divider will help some, but to really fix it you need to put down some proper noise insulation. I did just that with some BXT Raamat II from Raamaudio. Now at 70mph, windows down and radio blasting, I can have a normal conversation with my passenger. No way I could do that before.
Took me an afternoon to cover every inch of the tub to behind the seat, plus the vertical wall behind the seats...the metal plate resonates sound. When I replace the speakers I'll do the doors also...
I know the F1 Goodyears we had were HORRIBLE ... the sound would change with the texture of the surface of the road....that may be what you are hearing....Nitto tires will help that a LOT ... I know... been there done that!
It's not going to sound like a Beemer or Caddy... it will take some work to make it quiet...
1 Post
