Good deal?
Good deal?
Found a 03 92000 miles for 13,500. Everything looks good,is it a good deal?
The price for an 03 is excellent. The car is what you should worry about. Check past history, title branding, a/c, tires, HUD, etc. Check everything including pulling codes thru DIC just so you know what to expect in fixing any problems. A low price is not always the best deal, and there may be a reason it's low.
Received 2,706 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
Any reason other than I cant take it out? I can always replace the seal.other than that ,cosmedecly the car is perfect .
I would check it very carefully, if the owner will silicone in the roof to fix the leak, Lord knows what else gerry rigged "fixes" he's done...seen and unseen...
It shows how the previous owner took care of his car. Instead of fixing it correctly he just glued it down. It might be how he handled all it's problems. For me it would be a deal breaker.
Received 3,054 Likes
I would probably pass however it could be something simple like window tip-in adjustment or replacing the targa weatherstrip seals. Or the reason it leaks could be that the car was hit hard once. You may be taking a chance.
I thank he took good care of it. He's got a stack of recs.all the serv. done at dealer since new and all new f55 shocks.i thank it wasn't that impo.to take it off to him.
Good though,he did just replace the reg. On the drivers ,and that's were he has it siliconed
If the previous owner "fixed" the car by gluing the top to the body, I would think every part of the car the owner has ever touched is now suspect.
