passenger side air check valve fix?
Looks like a plan...I may consider it if mine ever finally hard-fails. (Note: if you have a 2004, the diagnostic code is P0492, not P0416.)
Two caveats:
1. I've met smog-check people who were **** enough to squawk about anything that doesn't look stock. Those bright shiny clamps and/or the cut end of the old pipe might get their notice.
2. I would not recommend the method that reuses the old passenger-side pipe, as it puts a piece of rubber heater hose on the exhaust (hot) side of the check valve. There's a good reason the factory setup uses stainless pipe between the check valve and the manifold. You could probably put a compression or flare fitting on the cut end of the pipe and then a threaded coupling to the new check valve, but that makes the whole thing more trouble than its worth.
Two caveats:
check valve
I looked at that procedure and considered doing it. I then thought about the fact that the original check valve lasted over 100,000 miles in the place it was, I then elected to pull the manifold off and replace the valve behind the manifold. I believe it took me about 2 hours to do the job. Just my opinion, wish you luck on whatever way you go.
Received 19,309 Likes
'20-'21-'22-'23-'24
Thanks for posting the link to the You Tube video. Interesting way to fix the problem.
i have an 01 and not sure if it will work but it seems that if you can relocate the part to a better more accessible location with out harming anything it would make sense.
thanks for the input
