Service active handling?
Did a couple of doughnuts in the parking lot at work this morning and "service active handling" popped up.. It went off and didn't come back on , no codes, etc .. Is that normal?
You will want this system to be servicable in case you ever need it on a spirited drive.
Have a close look at the 6" cable 3pin) that plugs into EBCM and also to connector near ground pack. The latter of which is located near dvr side lower hood shock hinge pivot point. Make sure its clean and connected right. Take a 10mm socket wrench and remove ground pack lug and look at separate wire lunette ring for dirt / rust.
I turn off the car, pull the key, wait a few seconds and it's all better.
Received 19,305 Likes
'20-'21-'22-'23-'24
Good information - thanks.
C1282 = YAW Rate Sensor Error.
Set when the calculated YAW differs greatly from the measured YAW.
Probably due to "doughnuts" you were doing but only time will tell for certain..........
Next time you decide to do doughnuts you might consider turning AH "OFF" first.....
Leaving it ON means that the computer is attempting to correct for things you are intentionally trying to do.
Did someone spill something in that area?
