Under floor board has a small crack from jack what to do?
There is a small dent not all the way thru but it need attention. Can I put bondo under it or does it need fiberglass fill. Never done this before. Suggestions.
Received 19,309 Likes
'20-'21-'22-'23-'24
Since your other thread mentions the ECM, I take it the area is behind the passenger wheel. Pics sure would help people here give you some advice.
St. Jude Donor '18
1) Go buy a set of jacking pucks.
2) Throw the car away because it's now junk...
3) ...or you could buy some MarineTex and fix it with that. Usually available at any marina or even WalMart in the boat isle.
