where to get Light bulbs for c5 climate control
99bluvet (09-26-2017)
I got mine at the local radio shack store 272-1092 2 per package.
#7219 12 volt 60ma
#7219 12 volt 60ma
2018 C5 of Year Finalist
St. Jude Donor '14,'18
If your display has gone dim then it means broken cold solder connections on the pc board in the module. An easy fix for free. Instructions on this forum to remove the module and where to re-flow solder.
Old thread but do these bulbs need to be soldered in, or are they twist sockets? I only have one bulb that is out behind the MODE button, but following RF's suggestion, I guess I should change them all. Just want to sort out what I'm getting myself into. TIA!
Soldered in bulbs. If I remember right there is 11 of them. You can search on the forum using dim/dark in the search box
https://www.corvetteforum.com/forums...splay-fix.html
Received 19,306 Likes
'20-'21-'22-'23-'24
Try this thread. Everything having to do with interior lighting is covered
https://www.corvetteforum.com/forums...od-thread.html
Had a couple of bulbs go out on my Silverado Climate Control panel so I purchased a kit through LMC Trucks. Come to find out the Vette takes the same bulb as i changed out a couple of them on the Vette too from the Silverado kit.
