ARH can't decide 1 3/4 or 1 7/8
i want to buy ARH for my 03 z06, can't decide on size. i want to do heads and cam in the future, not expecting to ever do more than 500 hp.
Received 1,261 Likes
if there is a chance you will boost the car or swap to a bigger motor in the future I would go with the 1 7/8's right off the bat... if you are dead set that you will never do more than heads/cam then the 1 3/4's will be fine... I wish 1 7/8's were offered at the time I originally bought my headers because buying them twice is not cheap at all
I have had both sizes on my car and can't tell any noticeable difference in sound... besides, that's not really the best way to choose which set to buy in my opinion
http://ls1tech.com/forums/generation...o-results.html
Apparently myself and several others are clueless. After all, you provided a link to one thread. I've read a lot on the subject, and I found more often than not that 1-3/4" longtubes were recommended for "low" power goals, by enthusiasts and manufacturers alike. YMMV.
Esser (06-27-2016)
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Stock Motor - 1-3/4"
Modified Motor - 1-7/8"
If you are doing Heads and Cam 1-7/8"...
http://www.customcorvetteaccessories...ngheaders.html
Regards
Chip
Regards
Chip
I one up your "one" thread with two threads:
https://www.corvetteforum.com/forums...e-headers.html
http://ls1tech.com/forums/generation...xperience.html
Even C6Z guys know that 1-3/4 is better, and they are on 427Ci
1-3/4 all the way.
1-3/4 all the way.
For a 346 ci trying to make close to 500 hp he needs 1 7/8. Determine your overall plan with what you are going to do to the engine as far as heads, intake, etc then have a custom cam that is optimal for the combo. It will make more power across the board than piecing a combo together
