How Do I Change "Auto" Setting on AC Dual Climate Control?
Do I simply adjust the temp and mode (where fan blows) and then puch and hold down "auto" to make it the new auto setting? I've tried this to no avail.
If only... I think auto just makes it more like a thermostat. You set a target temperature and it "gets you there". Never been a fan of auto (A/C or transmissions)
Hit auto, set temperature, select Mode, No need to select fan speed. You could even just hit auto and select temperature
I'm confused. If I hit auto first, it'll jsut take it to the default setting it's currently at. How do I make the auto setting to my ideal settings and keep it that way so that every time I hit Auto, it takes it back to my desired setting?
I don't have the memory option where you set the seats ,radio, but I guess you could set the HVAC and set it to your options for the key and fob you use....
C4 of Year Finalist (appearance mods) 2019
Each time you go for a drive select what ever temp you feel is best.
Hit auto and the car's electronic and electromechanical systems will automatically get it there and keep it there (in the least intrusive manner) for the entire length of your drive. That is what it is designed to do.
It's not a memory setting ... it won't remember the temp or fan speeds. It's an auto setting so that once you select the temp ... it automatically gets and keeps it for the drive.
