[Z06] 2003 zo6
Old 03-19-2017, 09:15 AM
RedDevil2003
RedDevil2003's Avatar
Default 2003 zo6
Does anyone know why my drivers seat will not keep it's memory position?? When I get in the car and set to the correct position it remembers as long as I'm driving it that day. If I don't drive it for several days the memory is lost. Thanks
Old 03-19-2017, 06:56 PM
Alex41
Alex41's Avatar
Are you accidentally using 2 different key fobs?
Old 03-19-2017, 07:45 PM
grantv
grantv's Avatar
... or are you maybe not setting it properly? You mentioned putting everything in the right spot, didn't mention setting it.
Old 03-20-2017, 09:22 AM
RedDevil2003
Default Same Key Fob
Alex I am using only one key fob. I get into the car and set the memory and it works fine for that entire day, but if I don't drive the car for several days it forgets and loses the memory
Old 03-20-2017, 09:24 AM
RedDevil2003
Default Setting Memory
I set the memory and everything works for that entire day that I drive the car, but if it sits for several days and I get back in the car the memory is gone and I have to reset it.
Thanks for the feed back
Old 03-20-2017, 11:23 AM
grantv
grantv's Avatar
If you're setting it right (holding number button on door until it bleeps, to matching FOB number), then I'll just consider this a bump to hope somebody more knowledgeable can help you.
Old 03-20-2017, 11:58 AM
TBH94
TBH94's Avatar
How is your battery voltage? It could be losing memory because your battery is getting weak.
Old 03-20-2017, 02:51 PM
chain_5001
chain_5001's Avatar
My car would do something similar but with the mirrors. I would have the memory set but then randomly it would adjust the mirrors to wherever it wanted. I think its just the electronics being old and just acts up. Anyhow, if its feasible for you just set the seat to where you want and unplug the harness. I know this isn't ideal but at least you won't have to keep adjusting it.
Old 03-20-2017, 05:24 PM
RedDevil2003
Default Thanks
I'm setting it correctly, but another member just brought up another thought and I will try my other fob and see if that works. Maybe it is only programmed to one fob. Thank you
Old 03-20-2017, 05:25 PM
RedDevil2003
Default Battery
Brand new battery. I am going to try my other fob and see if that holds the memory. Thank you for your input
Old 03-20-2017, 05:27 PM
RedDevil2003
Default Thanks
I am going to try my other fob first and see where that goes. Thanks for your input, but yes some of these old cars act up on the electronics.
Old 03-20-2017, 06:19 PM
grantv
grantv's Avatar
But you programmed it, you dont know which FOB?
Use FOB1 to open car, get everything where you like it, hold button 1 on door until bleeps.
Repeat for FOB2 for your significant other. Or just don't use it.
Old 03-20-2017, 06:38 PM
RedDevil2003
Default Thanks
OK Thank you, will give that a try
To 2003 zo6
Quick Reply: [Z06] 2003 zo6
