Rotors that do not rust!
I am looking to replace my front and back rotors. The current rotors are drilled and slotted, but show a lot of rust, especially in the holes and slots. Normal brake use does not clean-up the rotors well. Is there a particular type of rotor that does not rust? Do all drilled and slotted rotors rust? If I have to live with the rust, how do you clean the rotors?
Location: Los Angeles I'm here for a good time, not a long time!
If you search the forum I have seen some threads about sanding the rotors and then using a high temp black paint that prohibits rust. Like the stuff they paint BBQ's with. Good luck.
Location: Not QUITE the armpit of Southern Maryland, but scary close...
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '04-'05-'06
Received 19,305 Likes
'20-'21-'22-'23-'24
Zinc washed rotors will resist rust. Mine has stood up very well over the past 6 months.
Received 3,812 Likes
you can get 4 drilled and slotted and zinc coated rotors for 249 dollars plus 30 dollars shipping from sportbrakes.com
The zinc coating will prevent rust.
http://www.sportbrakes.com/
St. Jude Donor '03-'04-'05-'06-'07-'10
here is a tip even with zinc washed rotors.
Buy VHT silver high temp paint. Use a Qtip and paint the holes and slots...it will blend in and look great all the time
Can you use raybestos pads on those rotors?
If the holes and slots are rusting they were zinc washed before they were machined - not a very good practice!
I still have stock rotor on mine but when I changed brake pads I couldn't stand the rust on the center and edges. I pulled all four rotors off and took them to a local plating company. They cleaned and 'Bright Cadnium' plated all four rotors for $50 in a couple days. End of the rust story!
Originally Posted by AC54ME
EridaSpeeds.
sportbrakes rotor which are actually brembos, 249 dollars.
Both are drilled , slotted and zinc coated.
