C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Torque Management
Old 06-19-2005, 11:57 AM
leeman
leeman's Avatar
Default Torque Management
In my previous post where I asked about the Predator in an '04, the response was that it will disaengage torque management for more powerful performance off the line. Is this the same as competition mode?
If not what is the difference? And does the Predator adjust anything else, like shift points, fuel mixtture, timing, ETC?
Old 06-19-2005, 01:16 PM
'06 Quicksilver Z06
'06 Quicksilver Z06's Avatar
It is not the same as Competitive Mode.
Do a search as there is plenty already written here about Competitive mode, Torque Management, Traction Control and Active Handling.
You might also check http://corvetteactioncenter.com/foru...s=&forumid=150 and do a search there.
The Predator is a good beginner's tool, arguably the best out there for a beginner who is going to be doing the minimum bolt ons like thermostats, breathers and cat back exhausts. If you want to buy one, I have one for sale.
However if you are going to go to gears, headers and definitely beyond, then there are much better alternatives out there. To nail down your timing and A/F ratios, you will probably be better off with a PC based program with scanning and logging capabilities. The Predator for GM has no logging capabilities.
Old 06-20-2005, 02:28 PM
leeman
leeman's Avatar
Default thanks EB
Thanks EB
To Torque Management
Quick Reply: Torque Management
