C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Service ABS & traction control
Old 01-17-2014, 09:50 PM
Tim Hughes
Cruising
Tim Hughes's Avatar
Default Service ABS & traction control
My ABS and traction control lights are on. I know the simplest thing would be to get the DIC codes. Unfortunately I can't access the DIC it has "locked" up.
I do know that the problem is with the left front ABS because when I brake hard the tire locks up. Could the be a bad ABS sensor?
Also any suggestions on repairing the DIC?
Old 02-02-2014, 02:41 PM
jp260z
jp260z's Avatar
Start by scanning for codes.......most chain auto parts jobbers will do it for free(Autozone,Oreillys etc).......go from there rather than just being a parts changer.
Old 02-07-2014, 08:47 PM
k24556
Support Corvetteforum!
k24556's Avatar
Actually,your abs is not working at all. The wheel locking up either has the best brake bite or the tire with the poorest grip.
To Service ABS & traction control
Quick Reply: Service ABS & traction control
