C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Timing ??
Old Jan 22, 2014 | 09:19 PM
a/c man's Avatar
a/c man
Default Timing ??
Can anyone explain to me why some boosted cars only take 15* timing and others can take 20* my car seems to like lots from what my tuners have told me. I know meth and good gas are part of it may be compression too?
thanks for reading this and helping me understand why
Old Jan 24, 2014 | 01:51 AM
Soul per4mance's Avatar
Soul per4mance
It's mainly Compression. In addition each car is different and have their own needs.
Old Jan 24, 2014 | 10:14 AM
mchicia1's Avatar
mchicia1
Timing is just an inverse function of engine efficiency given the same octane.
The more timing your car needs, the less efficient it is. A lot has to do with dynamic compression, yes.
Old Jan 24, 2014 | 08:15 PM
The Highlander's Avatar
The Highlander
No.
Timing is an inverse function of cylinder pressure. The more cylinder pressure the less timing it needs.
Old Jan 24, 2014 | 08:28 PM
a/c man's Avatar
a/c man
Originally Posted by The Highlander
No.
So a low compression motor can take more timing?
Old Jan 24, 2014 | 09:29 PM
RedZMonte's Avatar
RedZMonte
ALOT of factors.. Just to name a few:
* Boost Level, Lower boost will accept more timing (traditionally)
* Compression
* TUNE... if the rest of the tune is junk, you will get KR before you maximize the Timing.
* Mods... Headers vs stock manifolds, Cam, Heads... ect..
* Maxing out fuel system.. Too small of Injectors or pump and you will not get enough fuel resulting in KR and again less timing.
In a FI car, Usually a Low compression setup will have Higher boost levels.... resulting in lower timing advance
S
Old Jan 26, 2014 | 12:34 AM
a/c man's Avatar
a/c man
* Compression
S
Thank you for info So would you think my car has a problem if it takes 23*timing to run its best at the track on 16lbs of boost with lots of meth? I always here everyone say dont put more that 17 in a boosted setup?
Old Feb 4, 2014 | 07:53 PM
Mike04's Avatar
Mike04
I've ran mine up to 21 advance at a little over 20lbs of boost with no knock on the dyno and at the track (lots of meth and 93). I didn't leave it there though. I've ran mine a lot at 18 deg. My compression is about 9.6.
For what all its worth, I know you read a lot about 14 degrees on high boost motors making big numbers... Mine runs a lot stronger with more timing too. I'm not a pro tuner, I just have been lucky and not blown a motor up in the last 8 or so years.
Old Feb 4, 2014 | 10:37 PM
a/c man's Avatar
a/c man
Thanks mike it makes me feel better about mine.
We must have a good tune and build to get away with that much timing .
Old Feb 4, 2014 | 11:22 PM
The Highlander
Given the same conditions as a high compression motor yes....
Even a cam'd engine can take more timing down low and less timing up top.. it depends on cylinder pressure.. the higher the cylinder pressure the less timing.
Usually you will see that vehicles with VVT tend to detonate easier... You augment cylinder pressure (torque output) you then need less timing to get the same or more power.
Timing can inherently be more efficient at a certain point in certain configurations... for the ls1 and 3.62 stroke, it appears to be somewhere in the 26-28 degrees... if you correctly design an engine (cam events, compression, fuel or boost) to run at that timing given the conditions you will get a very smooth power delivery a very smooth graph and more power out of the engine for a given configuration.
Old Feb 5, 2014 | 01:07 PM
robert miller's Avatar
robert miller
The last guy that tune my car put 20 deg of timing in it said no problems, and looks like it will take more, But didn't see any need in it and pulled it back down to 15 or 16 at WOT.
Old Feb 14, 2014 | 06:38 PM
RedZMonte's Avatar
RedZMonte
It depends on where you are putting the timing. if you have supporting mods to run more timing safely then do so. more timing down low will also help spool time and the car to make TQ lower as well as better fuel efficenty. My car is NA, My tuner had me up to 26* before Knock, he backed it back down to 25*and no problems. My other car (Supercharged 3800) will go up to 23* timing under boost but with higher boost its backed down to ~18-20* at WOT, and 23+ mid RPM for better fuel economy and drivability. If you can run more timing do so. if you back it down a couple degrees it will sacrifice power for safty. generally the more mods you have the more timing you are able to run... IE Headers, Cam/Rockers, Ported Heads, Exhaust..ect..
Any good tuner will adjust KR attach rate/recover rate and how much timing retard when detination occurs so it will still be safe but also run more consistant. You can also adjust the sencetivity of the knock sensor so you can eliminte false KR from vibrations/engine noise.
S
Old Feb 14, 2014 | 08:02 PM
a/c man's Avatar
a/c man
S
Thank you that makes sense
To Timing ??
