C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
tune
Old 03-06-2017, 09:23 PM
73ls1
73ls1's Avatar
Default tune
I have a 2002 LS1 in my 73 Corvette. I changed from a 3 wire maf sensor to a 5 wire maf sensor. My question is do I need to have it retuned ? Thanks for your info, Thanks Charlie.
Old 03-12-2017, 09:29 PM
tblu92
tblu92's Avatar
St. Jude Donor '13-'14-'15
On older C5's the MAF and IAT sensor are on 2 separate pigtails --
When you go to a later year MAF the MAF wires and the IAT wires are all combined into one 5 wire pigtail----As long as you pin the ECM correctly and do the wiring right all should still work properly---The only way to know for sure is to do some data logging of your IAT temps and MAF readings
PS I have tried this mod in the past---and found there was NO HP advantage and many driveabilty issues popped up--The stock early MAF's were plenty capable to work with approx 500 Crank HP Unless you are over this level --all you are going to do is create tuning nightmares and no extra HP----Typically you need boost in order to outgrow the early C5's MAF tables
Quick Reply: tune
