" Charging System Fault " Flashes on my DIC. What do I do?
Happened yesterday and today. I start the car in the am and the DIC says "Charging System Fault" and then goes away.
I have a new red top battery and the volt meter says it is fine.... Any ideas what this could be?
St. Jude Donor '05-'08
Mine was the altenator. My lights would also dim for a quick second at night.
Others have mentioned checking all the connections to your battery to make sure that they are all clean. I assume with the battery replacement you have done that, but it might be the place to start.
BTW - after I changed the altenator all problems went away.
I'll check all connections. Then I guess I will test the alternator. When an alternator fails does it fail in an obvious way or will it be an intermittened thing that will be hard to find?
Received 3,812 Likes
St. Jude Donor '03-'04
The L-terminal circuit from the generator is a discrete circuit (a discrete circuit has no splices and only one source and destination) into the PCM. The PCM applies ignition voltage to the generator L-terminal circuit. A small amount of current flows from this circuit through the generator windings to ground to create a magnetic field which starts the generator process. When the generator is at operating speed and producing voltage, a solid state switch for the L-terminal circuit in the generator opens and the PCM detects that the initial startup current flow has stopped.
The PCM expects to detect low voltage on the L-terminal circuit prior to the generator rotating at operating speed and conversely expects the circuit to be at ignition voltage potential when the generator is operational. When the PCM detects a fault (circuit shorted to ground, or circuit shorted to voltage), the Driver Information Center will display Charging System Fault.
The generator has an input to the PCM called the F Terminal to indicate the percentage of total capacity that the generator is producing. This signal is detected by the PCM as a duty cycle from the generator and displayed on the scan tool as a percentage. The PCM can monitor the generators output under all conditions to determine if it is functioning normally.
When there is low demand from the electrical system on the generator, a low duty cycle percentage will be displayed. As more accessory load is placed on the generator, the duty cycle output detected by the PCM will approach 100 percent. A normally functioning generating system will never reach 100 percent as indicated on the scan tool.
The L and F terminals are the red and grey
Thanks Evil twin.
So I should be looing for a grounded circuit?
Thanks Evil twin.
