FINALLY FIX your E-Brake!!!! - Pic's
Old 06-17-2005, 01:12 PM
DidntSettle
Support Corvetteforum!
DidntSettle's Avatar
Location: Manchester - Political correctness is tyranny with manners.
Originally Posted by UT-Driven
I had my car inspected last month after I bought it and got an advise on the e-brake. It doesn't work for forward motion and doesn't work as well as it should for forward motion. Do the symptoms sound like they will be fixed with this write up?
Thanks,
UT-Driven
You have a PM
Old 06-18-2005, 11:43 AM
speedfreek155
speedfreek155's Avatar
Good to know ,THANX
Old 01-09-2016, 07:07 PM
Keith Richards
Keith Richards's Avatar
Just wanted to resurrect this post as it helped me today! I knew my E- brake lever was the issue rather than adjusting the drum as once in a geat while it would catch and lock the car solid about 1/2 way up. I took the passenger seat out , pulled back the carpet and slipped the E-brake assembly out to were I could clean it with brake cleaner to get all the nasty, sticky original GM grease off, works perfect now. Before pulling the rotors off I suggest you pull the boot back a bit and shine a light in there and see if you see the cable moving, if it doesn't move this is the fix.
Quick Reply: FINALLY FIX your E-Brake!!!! - Pic's
