70+ rwhp/9mph trap speed gain from cam & UD pulley only + tuning on A4 C5
Ok, this is the last I will post on this particular cam install, but many of you continue to PM or email me requesting more details of Scoundrl's cam-only gains. Recap: I installed a custom grind 229/235 113lsa cam and UD pulley into Ken's 04 A4 2.73 stock TC coupe a couple weeks ago. Prior to the install he had a Vararam and cat back and was running 106mph traps and dyno'd 315rwhp. I did the install then I tuned the snot out of it in Speed Density mode. Since the install we've been to the strip to check out the gains: he ran 115+mph this past weekend and dyno'd 375+rwhp but AH/TC cut car off at 5400rpm, just when cam was starting to make its power!!! So, no telling where his peak power is, I am guessing close to 390rwhp or more. So, we picked up upwards of 70-80rwhp+ and a solid 9 mph in trap speed. This is through stock LS1 heads and the stock 4 catalytic exhaust system!! Car idle's pretty good at 650rpm but I plan some more fine-tuning to really bring it in. We may end up with an Idle speed of 700rpm, still low enough to avoid too much cam idle push most see with big cams and high idle speeds in stock-TC'd A4 cars. Once we put a looser TC in it I plan to put the idle to 600rpm to really get that cam lope going!! Ken seems to like it...
So, I am installing a little bit bigger cam into another A4 here shortly, but the customer already has Patriot heads, LT headers on. So the results should be very interesting.
Ok, dead horse beaten to death. Ken- you got a beast of a car. Imagine what ported heads, headers, gears and TC would do. Greg Nate, you're next!!! Cam should be here in a few weeks. Adam Bailey (killaz), you gonna pick up a h/c package for me to install and tune for you??!
RJ
RJ
Originally Posted by kumar75150
wait, so you got around 390rwhp on a cam only automatic car without headers?
thats freakin amazing
dont tell me he still has cats
What ET did the car run ? That's a decent trap speed for a cam only A4 with stock maniflods and cats , there was a forum member who ran 11.80's at 115-116 in a bone stock motor 99C5 A4 with T/C , gears and headers with cats , stock heads , stock cam .
Nice job Robert, you seem to know what you're doing!
Originally Posted by Face
That was Artie you're thinking of. IIRC, he ran a high 11.6 @ 115.
I am pretty sure this one would have hit 400. It was just starting to make good power when it crapped out! Since you have a 6 speed I'd go bigger.I'd go as big as I could w/out fly cutting it, I bet you'd be needing a cage with just a cam intall.
Originally Posted by SJTrance
You never mentioned what his 1/4 mile time was. Could you tell us the before and after times?
After install = 12.6@115.4, 375+rwhp (Traction control kicked in @ 5400 and killed the run. Cam was still pulling very hard. Hit 375rwhp at 5400 so I figure dam close to 400rwhp, maybe more? unreal).
His small ET gain vs huge trap speed gain is, of course, indicative of the stock 2.73 gears and stock Converter. With the power Ken is generating right now, if he had 3.73s and 3600SS stall and TransGo shift kit, car would be deep in the 11's. Not bad for a cam only car. Then add the LT headers, CNC heads, no cats; car would be a daily 10 second driver. However, Ken is not building a drag racer, so we wont be going this drastic on the gears and TC.
RJ / Gen 3 MS
The cam is a custom grind of my specs, but basically 229/235 .585/.595 113.5 +4 on XER Comp Cam.
Edit: Oops. my bad...I see Ken already answered your question....
