Differential Leak
Cruise-In VI Veteran
St. Jude Donor '05
Differential Leak
I have a 2000 coupe. I noticed a leak from the rear end. Took it to the dealer for the usual oil change and they told me that the rear diff cover was leaking. $1200+ to fix it, 14 hours of labor, drop rear axle and diff, etc. What do you guys think about this? I wouldnt have the dealer do the work, but is it worth getting it fixed? Or should I just upgrade to an entire new rear end? Are there any quick fixes that will stop the leak for the time being? The car has 33,000 miles on it. I dont drive it in the rain and will only be driving it once every few months. thanks a lot for the help.
Just had mine done at a local dealer last week. Ticket showed 2.9 hours. Remove left wheel, shock, and axle assy, left diff cover. Replace left cover seal and axle seal. Service writer said if it were not under warranty, I would be out about $400 parts and labor. I'd shop around, sounds a bit steep. Good luck!
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
If it is leaking from between the diff and tranny you will have to drop it. If it is just an output seal like the above post it is an easy fix. $1200 is ridiculous. If you were local I'd remove and replace diff for $300-350 just to make some extra parts money. $400 as the above post states is also excessive for the work done for the side seal replacement. You can see "how-tos" on my page here.
St. Jude Donor '05
hey thanks for the replies guys. I knew the stealership wasnt being straight. What parts will I need to fix it under both scenarios? e.i if the leak is between the tranny and diff or not
I think the output shaft seals are like $6 or $7. That is all you would need. If it is leaking from between the diff and tranny, you would just buy an o-ring. When installing the o-ring you would want to put a bead of sealer around the outside of it as well before you mate it back to the tranny. If it is leaking from the rear cover, that is just a gasket as well. All of the parts to fix the leak are cheap. You need to determine which it is. They are hitting you hard for the labor. If it is the rear cover or the o-ring, you will have to drop the driveline to repair. If it is the side seals, you will not.
I can fax you over a copy of my work order from Gm when I got my diff leak fixed. It has everything they did to it.
It has the part numbers as well. e-mail me jelucio@yahoo.com
When you guys notice the leak, is it from drips on the floor or a wet diff. My diff has been wet since I bought it when viewed from a lift. Never a drop on the ground. Could it possibly have been overfilled at Bowling Green and wicked out of vent early on when new? 1998 C5.
From my experience. If there is drips on the floor then you need to repair the leak. I read on here a long time ago, the differential has a vent and when you do over fill it. It does let some out, if your car has been sitting for a couple of days and there is a small puddle then you have a leak.
If you do not see anything don't worry about it. You would have a puddle of some kind it is obvious. Cheers!!
$1200 sounds way too steep. Most corvettes shops charge under $500 labor to R&R a rearend. I had a leak in mine "warrantee" ticket said 2.5 hrs they pulled the hole rearend
Most 'local' mechanics won't touch this because special [expensive] tools are required. I stayed with my car at the dealer while the work was being done, and really got an understanding as to what was involved. Getting to the Diff cover, typically (90+%) the left side or drivers side, requires moving most of the suspension out of the way. It's not a job most owners could do at home!
Cost Correction
My 2000 MN6 also leaked, out of warranty, and the total cost from my dealer was $530.
Resident moron
Remember, there's 2 possible types of problems here guys, and one is MUCH easier to fix than the other. Granted, neither requires 14 hours of labor (or even half that), but dropping the rear and pulling the diff to replace the diff->tranny seal is MUUUUCH harder.
Shop around. I see you're in Springfield, too bad you weren't a little closer, I'd do it for a reasonable rate. I'm right near Boston though.
Dope
Dope
