A/C compressor Oil
1 Post
A/C compressor Oil
Do theses GM compressors have an oil leak issue. I have found oil under the compressor , but the compressor is just moist on the underside. There is a wet spot below it. Does the heat dry it off the compressor case. What type of oil PAG ? Appreciate any feedback,Thanks
Cruise-In VII Veteran
