a/c idler pulley part #'s?
Cruise-In VII Veteran
i called beans and got 12557334, but they are not in stock
i can't find the part on rockauto.com, anyone replace these recently?
there are 2 idler and 2 tensions pulleys on the c5
i'm talking about the 1 idler and 1 tensioner pulley that runs the a/c system(lsx motors use a seperate built for the a/c sys)
also both pulleys from the a/c sys(idler/tensionser)are of polymer material and are the same part
just trying to avoid any confusion thanks
they seem a bit worn after 114,000 miles
just went to advance auto parts(does everyone there drive cavaliers w/monster tachs? wtf)told parts lady i need ac idler and tensioner pulley, i get the ribbed pulley and steel idler from the main system, the a/c pulleys are not in the system, flip the a/c system
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
12557334 is the correct # for the a/c idler pulley. (not 12557344 as you had stated in your post).
The tensioner part # is 12560345, but that is the complete tensioner. You say the actual pulley on it is the same, and that may well be, I don't know.
