Old 03-03-2015, 12:32 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
why does my car labor knock bad -ping ping
Old 03-30-2006, 08:11 PM
vet85
vet85's Avatar
Default why does my car labor knock bad -ping ping
my car has 40k on it .only run premium in it from day 1 and it pings like a 75 chev 4x4 with regular gas in it .oh yea its a 02 -auto .any ideas on how i can help it out .im open for suggestions as it is very embarrassing.it seems to be much worse if im going under 30 and punch it ...thanks .
Old 03-30-2006, 08:50 PM
Evil-Twin
Evil-Twin's Avatar
Received 3,812 Likes on 1,925 Posts
St. Jude Donor '03-'04
If you dont have any codes, I would suspect that you have carbon build up...you need to de carbon the engine... seach GM decarb procedure.
Old 03-30-2006, 09:42 PM
pewter99
Support Corvetteforum!
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
2 things I noticed buying gas from one particular station (Exxon)would cause pinging for me..I didn't really pay attention at first but I started to be concious of where I filled up and when the rpoblem started..so I stopped going there..also had the car tuned and that solved the rest of it...I also use Redline S1 every few tanks....I buy it by the case....12 bottles in a case I usually split the case with someone 6 bottles last me quite awhile since the car isn't my DD..
Old 03-31-2006, 12:25 AM
EVLZ06
EVLZ06's Avatar
Very dumb question but what exactly is pinging? I have heard it several times but not really sure.
Old 03-31-2006, 01:12 AM
allmee
allmee's Avatar
Another word for engine knock or pre-detination
Old 03-31-2006, 09:42 AM
Evil-Twin
Evil-Twin's Avatar
Ping is cause by the compression of the fuel and air mixture as it approaches top dead center. pre-ignition or ping is the result of the fuel air mix igniting under pressure before the actual spark, this puts the position of the piston before it starts into the power stroke... gas will ignite under too much compression pressure. Thats why you need higher octane to prevent the fuel mixture from igniting in a high compression motor... carbon build up will increase compression, and this build up can make pre-ignition possible.. Increased heat is also a part of the pre-ignition equation.
Old 03-31-2006, 09:43 AM
corvette Mark
corvette Mark's Avatar
Do you have any mods to your intake?
Old 03-31-2006, 10:36 AM
Tact
Law Dawg Moderator
Tact's Avatar
CF St. Jude Co-Organizer
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Try adding Tectron to your fuel.
Old 03-31-2006, 11:06 AM
greg_nate
greg_nate's Avatar
Its a rattling sound - much like a diesel engine. Sometimes people even refer to it as "dieseling".
You'll hear mostly during engine load - for example going up a hill, or when first shifting into a high gear such as overdrive, when you should be in a lower gear. The sound is more annoying than anything else because it should like engine is loose and falling apart.
Its more difficult to detect at higher rpm because of the high volume of the exhaust note...however, that's when its really dangerous and can cause damage.
Old 03-31-2006, 04:58 PM
MrLeadFoot
MrLeadFoot's Avatar
You're not running California/Nevada gas, are you? Been there, done that. Did decarbs, plugs, etc. Lower temp thermostat helped a bunch. But, the true fix is a custom tune, which includes spark advance adjustment.
Old 03-31-2006, 05:01 PM
SLPRC5
SLPRC5's Avatar
Dealership or DIY and a custom tune.
To why does my car labor knock bad -ping ping
Quick Reply: why does my car labor knock bad -ping ping
