Squeaking Shocks F45 Option
My 99 convertible has the electronic shock adjustment on the console; when it is set in any mode and driving slow over speed bumps both front and rear suspension let out a real groan and squeak. The dealer put it up on a hoist and pulled up and down on the cross bar to recreate the noise. The shocks perform fine but the squeak definitely comes from the shocks. We tried to lubricate the bushing but the noise did not stop. Replacing the shock seems dumb for just a squeak but there does not appear to be any way to lubricate things enough to stop the noise. Any suggestions or similar problems with these shocks. Everything is stock at the moment.
I'll bet if you take the bushings off the sway bars, front and rear, silicone grease the inside of the bushings, grease the sway bars where the bushings fit, reassemble, you'll find out that your shocks will stop squeeking.
Just curious, was it the sway bushings or those on the shock? I've had a thud coming from the RR area, and found the upper shock bushing torn today.
The follow up question is where could I buy an upper bushing for rear Bilstein Sport shocks?
