15-50 vs. 20-50 Engine Oil
Old 09-21-2006, 06:25 PM
Dirty Howie
Dirty Howie's Avatar
Default 15-50 vs. 20-50 Engine Oil
Is there any significant difference between these two wt oils.....both are 15K extended service fully synthetic.
Mobil1 15-50
Amsoil 20-50
The motor is a stroked 402 that consumes some oil, is a daily driver and sees 10 track days a year. Also live in sunny so cal .......
DH
Old 09-21-2006, 07:47 PM
Dave00C5
Dave00C5's Avatar
Thats some awful heavy oil viscosity to use.
Old 09-21-2006, 09:12 PM
vettenuts
vettenuts's Avatar
Even though they are both the same weight, you need to pull the actual Cst viscosity number for each to see what the difference is. Any reason why so high a viscosity?
Old 09-21-2006, 10:33 PM
Mr. Lucky
Mr. Lucky's Avatar
St. Jude Donor '06
Not for a stroker.
Howard, I'd be leary of the long-term effects of cold starting with a minimum viscosity of 20... even in sunny SoCal. If you want an alternative to the ext-perf Mobil-1 15w50, consider Red Line full synthetic.
Old 09-21-2006, 10:51 PM
brucemoose2
brucemoose2's Avatar
There's no way that I'd go 15k miles between oil changes with either of those oils, unless you're going to perform oil analyses at regular intervals... especially with track days in the plans.
The weight you choose depends primarily on the clearances set by whoever machined the parts for your engine. I assume that it's set up looser than stock since that's common in modified performance engines. Exactly how loose it's set up will help to determine the appropriate viscosity rating. I would ask your machinist or engine builder. Do you happen to know if the engine was blueprinted and if so, what your rod clearances are?
Old 09-21-2006, 11:22 PM
Dirty Howie
Originally Posted by Mr. Lucky
Not for a stroker.
Bob
Andy says its fine ..... no problem.
The only reason for the inquiry is that I can get the Amsoil A LOT cheaper and it appears that I am consuming some oil and put alot of miles on the car (500 per week)
Amsoil comes 20-50 not 15-50
DH
Old 09-21-2006, 11:26 PM
Dirty Howie
Change the oil every 3-4K miles depending on if I'm doing a track day.
Yes its built to looser tolerences and 15-50 was originally recommended....but 20-50 was okayed today.
DH
Old 09-21-2006, 11:41 PM
Mr. Lucky
Mr. Lucky's Avatar
St. Jude Donor '06
That's unusual to find Amsoil cheaper. Doesn't seem to be any downside then... go for it.
Royal Purple also makes an excellent 20w50, but I doubt that you can get it cheaper.
Old 09-23-2006, 08:12 AM
Dave00C5
Dave00C5's Avatar
Stroker or not the engine builder must have opened up the clearances quite a bit to use such a heavy oil. I use chevron 15w40 in my diesel truck fleet.
Old 09-23-2006, 11:28 AM
timemender
timemender's Avatar
Please be aware that Mobil-1 “Extended” does not meet the Corvette engine spec #GM-4718M.
This may be a concern of others who will read this post.
Old 09-23-2006, 11:54 AM
BLOWNZO6
Premium Supporting Vendor
BLOWNZO6's Avatar
I use nothing but 20W50 in my engine.. Havoline synthetic.
A 5W or 10W oil is just not enough when it is 100 outside and oil temps reach over 230.. IMO
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old 09-24-2006, 01:43 AM
Dirty Howie
Not giving you a hard time but why Havoline ?????
Everyone is using Mobil, Amsoil, Royal Purple or Redline .....
DH
Old 09-24-2006, 09:36 AM
BLOWNZO6
BLOWNZO6's Avatar
DH
Just what is available locally in synthetic in the weight I want.
No weight I want in Mobil... the other stuff is mail order from here. I don't run oil for any extended period of time, I change it every 3,000 miles so I don't see the point for spending $8 per quart on it. I have always used either Mobil, Havoline or Castrol and have never had any issues, so that is what I stick with.
Old 09-24-2006, 10:13 AM
GeorgeZNJ
Support Corvetteforum!
GeorgeZNJ's Avatar
St. Jude Donor '08-'09
I'm sorry to high jack the thread but, I had a friend order me some 20w50 Amsoil, to be used at WGI. Anyway he delivered it to me the day before, and it was 15w40. I got into it with him and it was just ordered wrong. I put it in drove 5 hrs to get there, 8 sessions, 5 hrs back. i still have 6 qts of the stuff left. I'm running Pocono next weekend 2 days. I'll change the oil this week, should I use the 15w40 or use something else. My car is a stock 346 w/lt's.
To 15-50 vs. 20-50 Engine Oil
Quick Reply: 15-50 vs. 20-50 Engine Oil
