MPH light on right gauge flickers.
Old 10-06-2006, 01:18 PM
Bluefire
Bluefire's Avatar
Default MPH light on right gauge flickers.
The blue/green "MPH" light on my dash was flickering between dim and bright on the way to work this morning. Headlights were not on so just that light was illuminated. Has anyone seen or noticed this before?
Old 10-06-2006, 02:24 PM
7898VETTMAN
7898VETTMAN's Avatar
I Have This Problem Also But Was Told It Is Normal.there Is A Sensor For It Located Above The Dic Buttons.if You Put Your Finger Over It It Will Go Dim.hopefully It Is Normal Or We Both Have Problems.
Old 10-06-2006, 02:35 PM
ICaughtVetteFever
ICaughtVetteFever's Avatar
I got it too, figured it was related to all my dash lights being dim.
Old 10-06-2006, 03:53 PM
Bluefire
Bluefire's Avatar
It was early in the morning, overcast must have been the light sensor.
Old 10-07-2006, 11:53 AM
New C5 Owner
Cruising
New C5 Owner's Avatar
Mine does that too. I could never figure out why. So, this is normal and there is nothing wrong?
Old 10-07-2006, 01:15 PM
Corvette Monkey
Corvette Monkey's Avatar
Mine too.
Old 10-07-2006, 11:29 PM
tsts
tsts's Avatar
Mine three!
Old 10-07-2006, 11:55 PM
Fartpipe
Fartpipe's Avatar
mine four
Old 08-09-2013, 09:12 AM
93civEJ1
93civEJ1's Avatar
Mine does that too...I just created a thread about it...but looks like it must be normal. I was getting annoyed.
Old 08-09-2013, 10:27 AM
Kmcoldcars
Kmcoldcars's Avatar
Guys, it is normal. When the sensor in the dash detects bright outside light it makes the MPH brighter so it can be seen easily. When you drive into a shaded area and the sensor detects darker outside light it dims the MPH so it does not blind you.
This is the same principle as lights in s long tunnel. They are set brighter in the daytime so the tunnel does not seem too dark. At night the lights are not as bright as your eye is used to the dark and the road department does not want you blinded by the bright light at night.
Old 08-09-2013, 09:57 PM
lionelhutz
lionelhutz's Avatar
Mine does it too, but I highly doubt it's normal on my car. It flickers too quick to be some switch between daylight and night due to a sensor and besides the ambient light condition isn't changing as it flickers.
To MPH light on right gauge flickers.
Quick Reply: MPH light on right gauge flickers.
