Need Advice for Z06 allignment...
Read the "sticky" Weights, Ratio's Strengths ect, ect... regarding Z06allignment specs. (I'll post that section here.)
My question is that I'm asking if any of you guys feel there should be any changes (or even opinions you could give me) to improve on whats already posted below???
The reason I'm having another Z06 spec allignment is that I recently installed new PS2's on Z16 wheels and raised the car up a tad.
Our car is not a daily driver and we don't track the car. But I would like it to handle pretty decent for weekend romps.
Appreciate any advice
Thanks, Bob
Alignment
Autocross
CAMBER: -2.5° front, -1.5° rear; CASTER: max; TOE: -1/8" toe-out, front; 1/8" toe-in, rear --- Source
C5 Service Manual Alignment --- Source
Front Individual Toe +0.04 degree
Front Sum Toe +0.08 degree
Front Individual Caster +6.9 degree
Front Cross Caster within 0.50 degree
Front Individual Camber -0.20 degree
Front Cross Camber within 0.50 degree
Rear Individual Toe -0.01 degree
Rear Sum Toe -0.02 degree
Rear Individual Camber -0.18 degree
Rear Cross Camber within 0.50 degree
Z06 Service Manual Alignment --- Source
LEFT & RIGHT FRONT:
Camber: Specified Range: -1.2 to -0.2 Optimal: -0.7
Caster: Specified Range: 6.4 to 7.4 Optimal 6.9
Toe: Specified Range: 0.15 to 0.25 Optimal 0.20
FRONT
Cross Camber: Specified Range: -0.5 to 0.5 Optimal: 0.0
Cross Caster: Specified Range: -0.5 to 0.5 Optimal: 0.0
Total Toe: Specified Range: 0.30 to 0.50 Optimal: 0.40
LEFT & RIGHT REAR
Toe: Specified Range: -0.06 to 0.05 Optimal: -0.005
REAR
Total Toe: Specified Range: -0.11 to 0.09 Optimal: -0.01
Thrust Angle: Specified Range: -0.10 to 0.10 Optimal: 0.00
Z06 (missing in '01) Service Manual Alignment - as written by Hib Halverson, but same as above --- Source
Front Individual Toe: +0.04 degree +/- 0.10 degree
Front Sum Toe : +0.08 degree +/- 0.20 degree
Front Individual Caster: +6.9 degree +/- 0.50 degree
Front Cross Caster: within +/- 0.25 degree
Front Individual Camber: -0.70 degree +/-0.50 degree
Front Cross Camber: within +/-0.25 degree
Rear Individual Toe: -0.01 degree +/- 0.10 degree
Rear Sum Toe: -0.02 degree +/- 0.20 degree
Rear Individual Camber: -0.68 degree +/- 0.50 degree
Rear Cross Camber: within +/- 0.50 degree
Thanks, Bob
Alignment
Autocross
LEFT & RIGHT FRONT:
FRONT
LEFT & RIGHT REAR
REAR
http://www.vbandp.com/instructions/h...ruct/align.htm
I use my roadster for a highway cruiser when it's not Winter up here. Aligned when new to essentially 0 camber, 0 toe, F&R, and 7/7.3* caster for crown compensation. Had to fight the dealer to get that done. This is on runflats. Zero abnormal or noticeable tire wear in 18,000 kilometres. Wouldn't change a thing.
I want to upgrade my alignment as well with my new Z16 wheels and GS D3's, but am waiting until after I install the DTE rear to get it done so I am very interested in the responses you get.
