i need help with a question?
i have a 2002 z06 with a vararam cold air intake but my question is that there is only one air filter from the front of the car right up to the intake manifold. Any guys out there have another types of secondary filter in between the Vararam and the intake manifold. This question is ask because where i Live there is a lots of dusty highway, and kind of scared in sucking to much dust in the motor. I know all of you have good ideals and can help out...Thank you
It is a good preventive maintenance job to periodically inspect the filter element in the varam. Start by checking each week. If the filter doesn't appear to be fouled, check every month, etc. Keep a spare filter element handy and change it out as needed. Normal replacement is every two oil changes, but that is based on "normal" conditions. Your "dusty" situation is not normal, so you need to determine an appropriate interval. Good luck and enjoy the ride.
inspections...........
To answer your question directly , NO i don't know of a replacement filter or secondary filter.
But remove your filter an inspect the inside mount surface and ducting for particulate matter. If you have dirt or grit inside then yes you have a problem with either the filter design or the sealing of the filter to the housing.
