Coolant Line Under Intake Manifold?
Old 12-31-2007, 08:01 PM
RrCoX22
RrCoX22's Avatar
Default Coolant Line Under Intake Manifold?
Is there one that runs underneath the LS1 intake manifold or are the rear coolant ports plugged? Curious for purchasing an LS6 intake manifold whether or not I will need a new front coolant line and some rear plugs.
Old 12-31-2007, 08:40 PM
SoSlow1
Support Corvetteforum!
SoSlow1's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
The 97-2000 model LS1's had the coolant pipe running under the manifold..If you are replacing it with a LS6 intake you will need the coolant pipe kit thru GM which plugs the rears and the new line will be in the front...
Old 12-31-2007, 08:58 PM
Russ K
Russ K's Avatar
This is a 2000 LS1 that I installed the LS6 coolant plugs & coolant pipe. Make sure that you remove the plastic clips for the knock sensor wires.
Russ Kemp
To Coolant Line Under Intake Manifold?
Quick Reply: Coolant Line Under Intake Manifold?
