Battery?
Cruising
Battery?
I recently traded my 2000 coupe for an 03 coupe. The dealer told me they had just put in a new battery. The battery is an AC Delco with 550cca. The original battery is 600 cca. Will this be a problem? I have had a charge system failure message a few times.
If I remember correctly mine 2003 has an AC Delco professional. Think it is around 700 CCA. The original owner had the dealer replace it before I bought it. I can go check it in the gararge if you need me to!
Here's my OEM battery. It lasted 7 years before I retired it (not because it died). Note the CCA number - it was certainly more than adequate for my 01 that has the upgraded stereo package.
