Yes, another Oil Thread - Mobil 1
Using the "optional" 10W-30 Mobil 1 (for my 2003 C5), and noticed that the container does not have the GM 4718M spec (only has the GM6094M spec, plus the Chrysler MS-6395 specs listed).
Going to Mobil 1 website, I see that the Mobil 1 10W-30 is approved for both GM specs (GM 4718M & GM 6094M).
Anyone know why I should not use this oil? Or run into this before?
Forgive me forum members, for I have sinned (again).
Plasticman
Plasticman
Don't like the breakdown of the increased viscosity index improvers in the wider range 5W-30, and here in central Florida we never see down below 20F, so prefer to use the (still GM approved) 10W-30 Mobil 1. Besides, the 10W-30 will help keep the cold engine piston slap gremlins away.
Just wondering why the Mobil 1 does not list the GM 4718M spec on the container (but is listed on their website 10W-30 spec sheet).
I guess an email to Mobil 1 is in order.
Thanks,
Plasticman
Thanks,
Plasticman
I spoke to a Mobil 1 technical rep a while back and he told me that 10W-30 oil in synthetic form is essentially, obsolete. There is no reason why anyone should need this viscosity, since 5W-30 Mobil 1 protects (flows faster) better at startup temps and easily matches high temperature performance.
And contrary to the tale of increased viscosity index improvers , synthetic oils like 5W-30 Mobil 1 do not inherently require index improvers as do non-synthetic oils.
The Mobile guy went on to say that even in Texas, he himself uses 0W-40 Mobil 1. 10W-30 is sold only because some people believe that it is somehow preferable over 5W-30, 0W-30, and 0W-40.
Received 1,675 Likes
It will be fine to use!
Although the Mobil 1 0W-40 is factory fill for some models of Porsche, BMW, and Mercedes, it does not carry the GM4718 spec. The Mobile rep did not mention the type of vehicle he had, but he did say that most engine wear occurs at startup, even at 70 degrees F. It is therefore a good idea to use a 5W-30 vs a 10W-30 synthetic oil.
In a synthetic engine oil 5W 30 will stay in grade as long as 10W 30.
5W30 provides quicker lubrication, better fuel economy and more HP.
I don't know why anyone would use 10W 30 unless they couldn't find the 5W 30.
Response from Mobil:
"Our Mobil 1 5W30 and 10W30 bottles carry the latest GM spec of 6094M. Both of these oils meet 4718M, and 6094M."
Just wondered why the 10W-30 container does not have the GM 4718M spec listed, and they did not answer that part of my question.
Plasticman
Plasticman
I think many people mistakenly believe that 10W-30 somehow provides better protection in high-temperature environments. That, of course, is completely incorrect. Just 20 years ago, some folks used only straight-weight 30 oil, thinking it was better than the multi-viscosity oils in hot climates. It took quite a while for that theory to die.
This is the same thing that my professor told us in one of my "Internal Combustion Engine" courses years ago. Here are the viscosities of a couple of Mobil 1 oils that I got a few years ago from Mobil.
Temp------5w-30------15w-50
-20----------6284--------21,852
0------------2129---------6462
25------------697---------1836
32------------531---------1348
50------------281----------657
100------------71----------138
150------------27-----------46
175------------18-----------30
200------------13-----------20
225------------10-----------15
250-------------7.6---------11.1
A 10w-30 oil's viscosities would fall about half way between the ones above at the colder temps and end up being the same as the 5w-30 oil at operating temps. At a 50 degree startup temp, there's a lot of difference between the viscosity of a 5w oil and a 10w oil.
The 5w (not to mention the newer 0w) oils provide quicker lube to your bearings and especially to your cam without any fall-off at operating temps compared to 10w oils.
While a 10w-30 oil sure won't lead to any quick problems, you're better off with a lower "first" number.
Also, as previously pointed out, good synthetic oils don't use any VI improver so they don't shear down like older multi-vis dino oils.
Plasticman
Plasticman
