How do you remove the front crankshaft seal without removing the timing cover?
Old 10-26-2008, 11:19 AM
crznZ06
crznZ06's Avatar
Default How do you remove the front crankshaft seal without removing the timing cover?
Hi guys, I thought I had posted this yesterday, but I can't find my post anywhere.
Anyway, I removed my wobbling stock harmonic balancer, and I want to remove the original crankshaft seal. How do I do this without removing the timing cover? Do I pry it out with a screwdriver? The previous posts that I've researched don't go into the details. Do I need any special tools? I don't want to damage the front of the crank.
Thanks in advance.
Old 10-26-2008, 11:57 AM
chrisok1
chrisok1's Avatar
I don't think its possible. You need to remove the timing cover, get it out by your method of choice (you are going to destroy it on removal), and press a new one in. Be careful on putting the new one in not to damage it.
Old 10-26-2008, 12:01 PM
MJD
MJD's Avatar
You'll need a seal puller. It'll cost you about 10 bucks from most auto stores.
Old 10-26-2008, 12:09 PM
vettekidc5
vettekidc5's Avatar
why would you not want to remove the cover? the gasket is reuseable... your making it harder on yourself
Old 10-26-2008, 02:30 PM
corvettebob1
corvettebob1's Avatar
How can removing the timing cover be simpler?
Just use a large screwdriver or a seal puller if you have one, then carefully seat the new seal in place. I used a section of PCV pipe I had laying around to tap it in place.
Old 10-26-2008, 02:59 PM
2MFFZo6
2MFFZo6's Avatar
That all its no big deal......dont over complicate things people
To How do you remove the front crankshaft seal without removing the timing cover?
Quick Reply: How do you remove the front crankshaft seal without removing the timing cover?
