305-35-18 Tire Question
Just an Ole Surfer Boy
NCM Ambassador
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VII Veteran
St. Jude Donor '04-'05-'08-'09-'10-'13-'14
On a stock C5 rear rim do the 305-35-18 tires stick out beyond the body? Anyone have a PIC from the rear with these tires mounted to a stock rim?
NCM Ambassador
Cruise-In V Veteran
I'm talking about a non Z06 C5 stock rim......
I think that 305 mm wide tire is a little too wide for standard C5 rear rim. They are a perfect fit on my 10.5 inch wide ZO6 rims.
Link to Nitto website specs for 555 RII Extreme.
http://www.nittotire.com/#index%2Eti...t555r2%2Esizes
A 305 has a nearly 2 inches wider cross-section than the OE 275. Thouogh it would fit and probably hold pressure, it is too wide for the 9.5 inch wheel. Side loads from spirited driving "could" cause the bead to fail....and well you can figure the rest.
Bottom line: I would not do it
NCM Ambassador
Cruise-In V Veteran
What is the widest tire you guys would suggest on a stock C5 NON Z06 rim. Is 295 to large also?
NCM Ambassador
Cruise-In V Veteran
Ttt
Here s my .02, You can listen to and do whatever you want but- I have a set of 305 35-18 on 9.5 rims(bought the car with them on it) and i have driven it at well over 160mph and NEVER had any problems, whether on curves or straight stretches. I would, and WILL do it again. Ask yourself this- "how many people do u know that have ever had a tire lose the bead?" I ll bet NONE. But, if you are like some on here, you won t dare put a 305 tire on a 9.5. I also have 335s on a set of 18x11!! OOOOOOOHHH NO!!!! You ll be fine, but thats just my .02, Its your choice. Peace- Jason
Jason,
...You can put me as the first one on your list of people who have lost a bead during "high performance" driving. Luckily I only tore up the rim when it happened. It used to happen a lot more than it does today. Tires are much better than they used to be. I actually do not think that losing a bead is likely with a 305 on a 9.5 inch rim. I do think that some 305 tires will not put the tread down flat when mounted on a 9.5 inch rim. This will result in poor tire wear and in some cases poor handling. What brand of 305 did you have on 9.5 inch rims?
Jeff
NCM Ambassador
Cruise-In V Veteran
Wheather 295's or 305's will the y stick out beyond the 1/4 panel on a stock C5 with stock rims?
Jason,
Jeff
Jeff
These are Nitto X-treme s. the wheel is a +50mm(that s what it says on the inside of the wheel). Looks to be wearing evenly. I don t have any pics, and can t take any for a few more days cause im changing the clutch right now. but they fit in the wheel wells just right without any sticking out.
NCM Ambassador
Cruise-In V Veteran
Hi Jacked...........
