c5 oil filler cap removal
Old 05-20-2009, 10:05 PM
george's2001c5
george's2001c5's Avatar
Default c5 oil filler cap removal
I tried to remove the oil filler cap on my 2001 c5. It turns but when I go to pull it off it won't budge. I know it comes out because I have had many oil changes. I know this sounds stupid because I have removed hundreds of these on other cars. Is there a release or a special grove to stop in and pull out.
Old 05-20-2009, 10:14 PM
PewtVette
PewtVette's Avatar
I had this happen just recently on my wife's Saturn. Over the years I've had the cap off numerous times but recently it has gotten tighter and tighter until last weekend when it wouldn't budge and I had to pry it off- the thing was wedged on tight! I borrowed the one off her brand new Solstice and it went on and off with ease. I picked up another oem cap and it works great. It's almost as if the orginal cap had slowly expanded over the years- perhaps due to heat.
Old 11-25-2014, 11:08 AM
harborgroup
3rd Gear
harborgroup's Avatar
Default oil cap removal
me too. I'm a new member and am trying to remove the oil cap to take the cover off to clean things. the cap turns a half turn and then is STUCK!!! I do not want to force anything. any ideas? thanks
Old 11-25-2014, 11:22 PM
Last C5
Last C5's Avatar
The oil cap is designed to turn 1/2 turn then pull straight out. It may be just the second half of the process (pulling straight out) that's giving you a problem similar to the previous posters.
To c5 oil filler cap removal
Quick Reply: c5 oil filler cap removal
