How do you switch out the main board on a gadge cluster
Old 06-11-2009, 05:20 PM
  #41
Mike99FRC
Mike99FRC's Avatar
Originally Posted by schpenxel
I know what an EPROM is and think I've answered the question in the previous post.
Yes, you can transfer that board to another cluster and transfer the mileage. Somewhere in this thread someone agreed that they had done it succesfully.
Ok thanks. Does that green board control the DIC too? That's the problem I'm having right now. If not, i'll just buy a cluster on the auction site and transfer that board on my old cluster to the new one. Also does that chip come out or can I just swap boards?
Old 06-12-2009, 03:04 PM
  #42
dgrant3830
dgrant3830's Avatar
Wounded Warrior Escort '11
Sorry, I wasn't implying anything. Most people wouldn't have a clue, so I apologize.
Old 06-12-2009, 10:10 PM
  #43
chevy406
chevy406's Avatar
....Somewhere in this thread someone agreed that they had done it succesfully.
I'll just continue to sit here in my corner, with my donor Z06 cluster showing the proper mileage in my '99... continue the discussion.
Old 06-13-2009, 03:10 AM
  #44
tstar
tstar's Avatar
St. Jude Donor '11-'12-'13-'14-'15
And you swapped the main mother board NOT the smaller board correct?
Tim
Old 06-13-2009, 08:11 AM
  #45
vette.mix
vette.mix's Avatar
Tim
Last weekend I tried swapping out the small board and it did not change the mileage, I think you need to swap the mother board and on the 97,98 and early 99s the mother board will not have the HUD connection
Old 06-13-2009, 07:21 PM
  #46
tstar
tstar's Avatar
The one on the bottom left of the cluster as seen in this picture has odometer information on it. The actual info is just on the black chip you can see on the right middle of that board
I did a quick write up and pictures to show how to remove the DIC circuit board, which also is the odometer. I did this procedure when I added HUD and a Z06 cluster to my '99 FRC. That way I kept my '99 171k odometer in the Z06 cluster, and left the 8k mile odometer to sit in my attic...
http://forums.corvetteforum.com/c5-t...post1570380674
OK so it's two to one....
Tim
Old 06-13-2009, 11:42 PM
  #47
chevy406
chevy406's Avatar
I didn't touch the smaller circuit board in either of my clusters...
Old 06-15-2009, 05:44 PM
  #48
buoniconti81
buoniconti81's Avatar
Vet.mix and I have a 1998. So Anybody prior too 1999 cant just change out the board because we have non hud circuitry. So Go to a tech 2 person, and pay the few hundred bucks... I wish it was that little circuit board on the left, but oh well.
Old 06-15-2009, 05:45 PM
  #49
buoniconti81
Also the check engine light has to be relocated too. Just too let you all know.
Old 06-16-2009, 02:03 AM
  #50
tstar
tstar's Avatar
/\ Good info! FYI some earlier 99's may or may not have the HUD connector.
Tim
Old 08-14-2009, 02:55 PM
  #51
Mxzx
Mxzx's Avatar
I think you mean the Airbag light has to be moved, not the CEL.
Old 06-01-2011, 03:00 PM
  #52
ls1k5
ls1k5's Avatar
Originally Posted by Calgary
If your DIC has stopped working, it is the small green circuit board in the last of the above pictures (lower left corner).. This also stores your mileage information.
If you replace this circuit board, whatever mileage is in the replacement board is what your DIC will now display.
g
I had the same problem with my cluster so I bought a new one that worked, swapped in the board behind the fuel gauge from the cluster that didn't work and the DIC still worked and the mileage was still the same. Has this worked for anyone?
Quick Reply: How do you switch out the main board on a gadge cluster
