1999 C5 Corvette Turn Signal and Dash Lights Problem
Old 07-31-2009, 02:52 PM
0Stealth0
0Stealth0's Avatar
Default 1999 C5 Corvette Turn Signal and Dash Lights Problem
I have been trying to find an answer to this question for a while now.
My left turn signal (rear) light does not flash when turned on. The system acts like there is a bulb out and flashes fast but I have checked all the bulbs they are fine. The hazard lights make the tail lights flash as well. When the turn signal is on and I am braking the tail light does not light up at all. The problem used to be intermittent and would only happen sometimes but now it always happens.
My second problem (which may be related) is the interior dash lights do not light up when you manually turn on the interior / head lights. The lights do however turn on when the twilight option is on and it is dark enough that the system turns on the head lights.
What could be the cause of these issues?
Any advice would be of great help!
-Thanks
Old 08-01-2009, 02:51 PM
RWE 427
RWE 427's Avatar
Do you have Euro tail lights?
Old 08-01-2009, 04:35 PM
0Stealth0
0Stealth0's Avatar
No they are the standard tail lights that come with the C5.
I have heard some people say that if you hit the dash near the hazard lights that it might fix the problem but I tried this and it did not work. I do not think it is the hazard light switch.
I do not know what else I can try to do. I was thinking it could possibly be a bad turn signal lever but I don't want to go through the hassle of replacing it if there is a more common problem that may be causing these issues.
Old 08-02-2009, 09:21 AM
lionelhutz
lionelhutz's Avatar
I'd bet the first problem is the signal switch in the column.
The individual signal wire runs do not go through the hazard. The hazard switch is just the flasher for the signals. If you have lost signals on one corner it can not be the hazard switch.
The second problem is likely the headlight switch. That seems the most likely since the twilight option bypasses the headlight switch.
Peter
Old 08-02-2009, 12:51 PM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
Peter
Very plausible and........coincidentaly enough..........all those functions are in one place. The (so-called) multi-function switch or headlight switch. Senor Curlee should have a nice sticky on the care and feeding of that little puppy.
Old 08-02-2009, 07:17 PM
dgrant3830
dgrant3830's Avatar
Wounded Warrior Escort '11
Yeah, I tend to agree also with the headlamp switch. They've got a serious failure history
Old 08-02-2009, 10:37 PM
0Stealth0
0Stealth0's Avatar
So this post Here would be the best guide to follow?
Thanks for the replies!
-Peter
Old 08-04-2009, 10:09 AM
drew47000000
drew47000000's Avatar
Very VERY likely the Multi function switch. Order the part online for 140-150 and do the labor urself. GM gets 800 for parts and labor. If your in Central FL ill help you. Its a little tricky.
Old 08-04-2009, 10:46 AM
phils C5 vette
phils C5 vette's Avatar
St. Jude Donor '12-'13-'14
Im noticing my flashers are begining to develop a intermint problem sometimes working and sometimes not. I can push the flasher button and the blinder starts to work again.
Will your part fix my problem? Im in Tampa
Old 08-04-2009, 11:36 AM
0Stealth0
0Stealth0's Avatar
Where is the multifunction switch located?
Old 08-04-2009, 02:22 PM
MattB
Support Corvetteforum!
MattB's Avatar
Its the turn signal stalk. Its called multi function because it does more than just the turn signals. Its not a bad job to replace, just a little PIA.
Old 08-04-2009, 02:24 PM
MattB
MattB's Avatar
I don't think so, do some searches on the hazard switch. I haven't had the issue, but it is different.
Old 08-04-2009, 05:57 PM
lionelhutz
lionelhutz's Avatar
Nope, that is likely the hazard switch going bad. Look for the DIY flasher bypass in the Ultimate DIY sticky post.
Peter
To 1999 C5 Corvette Turn Signal and Dash Lights Problem
Quick Reply: 1999 C5 Corvette Turn Signal and Dash Lights Problem
