goodyear gatorback serpintine belt
Old 10-07-2009, 11:23 AM
kismybass
kismybass's Avatar
Default goodyear gatorback serpintine belt
I have a 1999 vert. What is the right part number for a goodyear gatorback belt. The guy at auto zone gave me 4060798 but after searching other threads im confused some say use a 4060802
Old 10-07-2009, 12:33 PM
lucky131969
lucky131969's Avatar
No need for confusion. Go to the below site and find the part numbers in question:
http://www.goodyearep.com/productsdetail.aspx?id=3128
If you want to be certain, measure your factory belt, and compare it to the goodyear specs.
Old 10-07-2009, 02:57 PM
Sully1882
Support Corvetteforum!
Sully1882's Avatar
The goodyear gatorback belts are just a tad bit shorter.... this makes them a bit more of a pain to get installed but they are great and are quiet too!
hth,
Sully
Old 10-07-2009, 04:01 PM
Y2Kvert4me
Y2Kvert4me's Avatar
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
4060798 is the correct #.
The slightly longer 802 was used on 02/later cars with the clutch-type alternator pulley. (I believe that's why the slight difference in belts).
Old 12-24-2009, 04:22 PM
dbaction
dbaction's Avatar
changing both belts. any tips would be appreciated. Thanks
Old 12-24-2009, 06:17 PM
BOTTOMS UP
BOTTOMS UP's Avatar
I'm fairly sure they use the same size belt
Old 02-27-2012, 09:10 PM
Vette_Fan
Vette_Fan's Avatar
Default MAIN Belt - which one ??? 1999
Waking up an old thread............so you guys won't say I didn't use the "Search"....
For the 1999, stock engine... Which one is the MAIN (alt, water, etc...) belt - 4060798 or the 4060402.
Changing both belts and idler pulleys and tensioners....gawd dang just gonna do 'em all
To goodyear gatorback serpintine belt
Quick Reply: goodyear gatorback serpintine belt
