HELP Alternator parts numbers 1999, 2000 & 2001
I need some help here guys! My 2000 needs a new alternator. It has the 110 amp french made Valeo unit that is not serviceable or so I have been told. You can not just put in a replacement from Autozone or Napa b/c the circuitry is not the same and will cause the " charge system fault" to show up in the DIC. The numbers off my alternator are as follows:
GM part # 10316182
Valeo # A14V139
There is a New Valeo 110 amp one on ebay but the numbers are different, they are :
GM part # 10246634
Valeo # A14V121
will this one work for me?
If you guys could look... what are the parts numbers on your cars??? 1999, 2000, and 2001. I think in 2001 they changed to the 145 amp unit and that wouldn't work for me unless I had the BCM re-flashed.
Thank you all for your help,
Sully
GM part # 10316182
Valeo # A14V139
GM part # 10246634
Valeo # A14V121
Sully
by the way, my 2000 is a coupe and is an automatic trans with the 3:15 performance axle... in case that makes a difference.
who knows...
who knows...
