slight noise when turning the wheel
Old Nov 4, 2009 | 06:00 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Default slight noise when turning the wheel
Temperatures dropping and tonight when I turned the wheel I get a slight noise like leather squeaking against leather.
Not really loud, but noticeable. Anything?
Thanks in advance.
Jim
Old Nov 4, 2009 | 07:18 PM
SDPC's Avatar
0SDPC
Former Vendor
Sounds like the standard C5 steering wheel squeak.
Old Nov 4, 2009 | 07:29 PM
Benpup's Avatar
Benpup
Cure????
Old Nov 4, 2009 | 09:30 PM
SDPC's Avatar
0SDPC
Former Vendor
Lube, preferable lithium grease. Spray it in with the red tube where the column goes through the firewall. If you get under there and turn the wheel you will hear exactly where it's coming from. It's pretty simple
To slight noise when turning the wheel
