99 FRC No high beams
I was driving home last night and had my headlights on and when i pushed the lever forward my headlights went out.
I switched back to my low beams and the came back on, i did this a couple more times wiggling the switch and nothing,no high beams and no high beam indicator on the dash.
If i pull the lever toward me the low beam and high beams come on including the high beam indicator light on the dash but no high beam indicator light or high beam lights in the high beam only position.
Any ideas where to start looking for problems?
Sounds like an issue with the multifunction switch. Search "multifunction" and you will have lots of reading.
Here is one thread:
http://forums.corvetteforum.com/c5-t...f-replace.html
Here is one thread:
Here is one thread:
Here is one thread:
Mfs
There are alot of people having MFS,s going bad I replaced mine recently, I was having a turn signal issue. You can go to thepartsladi they have new delcos $143.00 that was the best price I could find.
