Racing Slicks on a C5
Has anybody tried running slicks on their C5? If so what tires and rims did you use. I would like to try a set of Hoosiers new slicks.
98 A4 Metalic Purple
powerloaded
Donaldson Blackwing
172 t.stat
Pro Torque 2400
3.42 gears
[Modified by Mitch C, 4:19 AM 3/25/2002]
powerloaded
Donaldson Blackwing
172 t.stat
Pro Torque 2400
3.42 gears
Re: Racing Slicks on a C5 (Mitch C)
I am looking at getting CCW setup. 16" rims and Hoosier now has some 16" SLICKS that fit on them. Search for a post under "hoosier" or racewheel screen name. There is a nice pic of the setup. :cheers:
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Re: Racing Slicks on a C5 (intel55)
Yep..........quite a few members are running the ET streets :yesnod:
ET Streets are not slicks,they don't hook much better than a drag radial,ET Drags are slicks but they only come in 15-inch sizes.
Re: Racing Slicks on a C5 (STEALTH C-5)
I'm running the 28 inch Hoosiers now. I went to the track Saturday to do some testing on the new Engine. It was still pretty cold, but ran a couple of 1.61 and 1.64 60 ft. I don't have my car algined yet for my new setup, but was happy with the 60 ft on a cold track. I'm just running N/A until I get it tuned, then I will Spray it. I'm running lean and 10 degrees of KR. It only run a couple of 11.40s @ 119. I have the LS1 edit now and will get it tuned soon.
The ETs and Drag Radials work fine on well preped tracks, I have to deal with bad tracks, so I figure if I can get traction on the bad tracks, Look out if I ever get on a good track :eek: .
Tom
[Modified by Tom Hall, 5:23 AM 3/25/2002]
Tom
