wobbley seat repair question
Old 11-28-2010, 07:02 PM
daleweible
daleweible's Avatar
Default wobbley seat repair question
I have taken my drivers seat out to repair the wobble in the seat. I had printed off the shim repair but after I have the seat out the wobble comes from the left track where the track bracket attaches to the seat frame The bracket appears to be die cast metal. It appears to be held by a roll pin where the bracket attached to the seat frame. The attach point is a 4 sided [square] shaft. The only movement I have is at that point front and rear. The right side is solid with no movement. Any fix suggestions. Its is not the rubber bushing on the drive worm gear. I am also fixing the recliner and it appears you have to replace the assembly cables to get the new shaft. FYI 2001 vert.
Quick Reply: wobbley seat repair question
