B&M Deep Pan.... special filter?
I have a B&M deep pan on my 1997 4l60e transmission. I installed it years ago and I can't remember if it needed a special filter. I know it has an extension on the filter but I just want to make sure I can use and OEM replacement. Also what fluid do you recommend? I think I put Trick Shift last time...? Thanks in advance for the help.
St. Jude Donor '13-'14-'15
I have a deep alum pan on my 98 can't remember the brand--- but it did NOT come with an extended pick-up either---Just it is very important to keep the level full at all times (according to the manufacturer at the time of purchase) the added oil alone keeps the oil from heat soaking and keeps the temps down along with the cooling fins---
