X pipe question
Old Feb 15, 2011 | 02:34 PM
Kingman99's Avatar
Kingman99
Default X pipe question
Hi
I have a 2002 auto coupe with the Z06 Ti exhaust, what will the X pipe do for me??
Alan
Old Feb 15, 2011 | 02:50 PM
memphis_vette's Avatar
memphis_vette
It helps with the motorboat sound and I believe popping on decel
Old Feb 15, 2011 | 02:55 PM
Kingman99's Avatar
Kingman99
Hi
Are you saying that it will sound smoother? Wht does popping on decel mean?
Alan
Old Feb 15, 2011 | 02:59 PM
memphis_vette
Yes it will Smooth out the exhaust note. From what I have heard on the forum Is that sometimes these car will have a popping sound on decel. Mine did it a little and the x pipe helped out
Read here
http://www.carcraft.com/techarticles...ion/index.html
Old Feb 15, 2011 | 03:07 PM
Kingman99's Avatar
Kingman99
Hi
The funny thing is that l have not had my vette out since Nov and l forgot what it sounded like. If l start it l will drive it!
So l will wait for the snow to melt and then take it out for sure which will probably be in April hahaha
Old Feb 15, 2011 | 03:59 PM
wcsinx's Avatar
wcsinx
If you're running the stock Z06 exhaust, then it won't change much. But if you switch out to very unrestrictive system like B&B Bullets et. al. then you'll tend to get a lot of decelleration crackle and motorboat idle. A proper x-pipe will alleviate a lot of that.
Old Feb 15, 2011 | 04:52 PM
BBExhaust's Avatar
BBExhaust
Premium Supporting Vendor
These guys are right on track. The x-pipe will make a smoother exhaust note and reduce some of the deceleration popping on the more aggressive systems like the Bullet. The only other thing an x-pipe will provide is a slight increase in power however it is minimal, 2-3hp. We have seen this on a chassis dyno however it is not something you will notice seat of the pants. We have more information on how we manufacture our x-pipe at www.bbexhaust.com.
__________________
David Merkel
Marketing Dir.
Billy Boat Exhaust
Old Feb 16, 2011 | 06:01 AM
Atok's Avatar
Atok
I disagree. I changed the sound of my Z06 significantly. It smoothed the sound out, especially at high RPM. It eliminated the exhaust "jingle" Z06's are known for (main reason for installing it). At 2500rpm the resonance is slightly louder.
I'm very happy with mine. At high RPM it almost sounds exotic.
Old Feb 16, 2011 | 08:40 AM
warren s's Avatar
warren s
Alan
Save your time and money, really.
W
Old Feb 16, 2011 | 09:01 AM
jrose7004's Avatar
jrose7004
I don't think you'll really have a motorboat sound at idle so it won't do much for you with TI's.
Old Feb 16, 2011 | 11:12 AM
wcsinx's Avatar
wcsinx
No doubt it will have some effect, but with a stock exhaust setup, Z06 or otherwise, the change is minimal as compared to a virtually wide open system like Bullets. On my B&B Bulleted '02 coupe, when I lifted off the go pedal while in gear, it used to sound like a hail of gunfire. Now it's more like someone with no rhythm on a bass drum.
Old Feb 16, 2011 | 11:50 AM
warren s's Avatar
warren s
To put on a X-pipe with a stock exhaust you have to cut the existing h-pipe. If you do it yourself its just the price of the x-pipe, to have it done your looking at a decent amount of money for a relatively minor change.
Old Feb 16, 2011 | 06:13 PM
Atok's Avatar
Atok
Agreed. It does change the sound, but to someone who doesn't drive the car everyday it would go unnoticed. Open exhaust would be much much louder. Also, I do not believe there is any performance gain. It does get rid of the "jingle" which is what I wanted.
Old Feb 16, 2011 | 06:30 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
The jingle might be in the cats, no?
Old Feb 16, 2011 | 08:04 PM
flynhi's Avatar
flynhi
I've installed X pipes on a 383 and my current 410 HP LS 1+ and, in both cases, the exhaust noise was reduced somewhat, the tone of the exhaust went up one octave and resonation decreased. I can't say that HP or performance was significantly inproved, but I liked it much better than the H pipe.
Old Feb 16, 2011 | 09:49 PM
Atok's Avatar
Atok
No, it's caused by the small hole in the factory H-pipe. When you install the X-pipe the cats stay in place. Only the H-pipe is swapped out.
The exhaust resonates in the H which sounds like a "jingle". I'm not sure if the LS1 does this but the LS6 definitely does. Lots of post in the Z06 section.
To X pipe question
