Replaced the EBCM, now car wont start
Old 04-04-2011, 11:32 PM
Redeasysport
Redeasysport's Avatar
St. Jude Donor '05-'06
FYI here is his car for reference
http://forums.corvetteforum.com/c5-c...tron-blue.html
Old 04-04-2011, 11:33 PM
bsalie99
bsalie99's Avatar
Bill Is there a write up in what I should be checking and what the correct voltages are?
Old 04-04-2011, 11:40 PM
lucky131969
lucky131969's Avatar
Originally Posted by bsalie99
I pulled the codes when i got the car and got
P1571
C1248
C1254
U1040
and a code for the outside air temp B0333
Brandon at ABSfixer said it was the EBCM that was fried and that he could not fix those codes
So I got a New EBCM from a dealer swaped it in and now get no comms
Here's the bad news. A C1254 will cause what you are seeing, as when it sets, the EBCM will not communicate on the class 2 serial buss. In conjunction with the C1254, a C1248 will set also. Like Bill said, time to get out the meter, and go through the 12 volt and ground checks, at the connector. Kinda looks like you have a bad harness/plug....maybe.
Old 04-04-2011, 11:42 PM
lucky131969
Old 04-04-2011, 11:44 PM
madmatt9471
Support Corvetteforum!
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
P1571
C1248
C1254
U1040
Where is the old one at?
Can you swap it back in and see if it gives you "NO COMM" for the old one as well?
That would also help as a test! But like Bill said you now need to check the actual power supply wires to see if you have "ACTUAL" voltage!
Thanks,Matt
Old 04-04-2011, 11:50 PM
lucky131969
.....why didn't I think of that...
Old 04-04-2011, 11:55 PM
madmatt9471
I think it is because I had my wisdom teeth pulled saturday and I still on meds - other than that we'd have him pull the motor and send it to us
Thanks,Matt
Old 04-04-2011, 11:59 PM
lucky131969
Thanks,Matt
I was being facetious......I mentioned it 15 post ago.......
Old 04-05-2011, 08:22 AM
bsalie99
bsalie99's Avatar
Do I have to reinstall the old one to test it or just plug it in?
Old 04-05-2011, 08:32 AM
lucky131969
What is the outcome of the 12volt/ground checks?
Old 04-05-2011, 10:11 AM
madmatt9471
need to check these!
It is best to install it like you would if it is new and you are ready to drive - one ground source comes from the ABS unit itself!
Thanks,Matt
Old 04-05-2011, 10:49 AM
dougbfresh
dougbfresh's Avatar
Just unplug the harness, the car can run without the EBCM, at least you'll know the car starts again then you can try troubleshooting.
Old 04-05-2011, 11:51 AM
  #33
MG RED 99
MG RED 99's Avatar
OP already said in previous post that he replaced the battery and car now starts
Old 04-05-2011, 04:21 PM
  #34
bsalie99
bsalie99's Avatar
I am headed off to Hawaii for 2 weeks, then I will have to dive back into this issue. I have not had time to do the voltage checks with all the last minute stuff for the trip
Thanks for the help, I will revive this when I return
Old 08-29-2011, 01:56 AM
  #35
DeeGee
DeeGee's Avatar
I was checking a similar problem for a guy in England. What was the outcome? Did you find a connector problem?
Quick Reply: Replaced the EBCM, now car wont start
